Discussion topic: Sky Sports player on PC streaming too fast
Message posted on 15 Apr 2023 03:52 PM
Streaming sky sports through the online window player is not working correctly. It has something to do with the audio, because it works at normal speed when I select a different audio playback device. It doesn't however work when I select playing audio through my speakers.
This is a recently new issue, I have not encountered it before.
Sky, please fix.
Message posted on 13 May 2023 12:50 PM
Re: Sky Sports player on PC streaming too fast
I managed to fix this myself albeit nobody from sky responded.
To fix this issue I reset the App volume device preferences within windows to default then it worked.
Hope this helps others.
Message posted on 13 May 2023 03:52 PM
@Snowbadger83 not sure if you are aware you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
Message posted on 07 Apr 2024 04:16 AM
You are a legend thank you so much - this has been bugging me for ages !!!!!!!
