Discussion topic: Sky Go seems unstable
This message was authored by: basilfaulty
I have been using Sky Go for years but recently some odd things have happened. When I open the app on my laptop it opens in a window approx one third of the screen size which is fine however when I try to drag the window larger from the bottom corner there is a point at which the app just closes down. This is quite annoying and I'm sure it never used to do this. Even just dragging the window to another part of the screen caused it to close down. Is anyone else having this happen? Other windows don't do this.
Re: Sky Go seems unstable
@basilfaulty
Have you tried uninstalling it then installing it again ?
If this doesn't help could another running program or app be causing this to happen ?
Avatar for basilfaulty
Level 2 icon
no I've not tried re-installing it but it seems to working ok today. Thanks anyway.
