Discussion topic: Sky Go is not functioning
This message was authored by: Tascon
After 21 years with Sky ( diamond member) I cannot get Sky Go to function. It just says " cannot connect with server". Everything else works perfectively.
what is going on. Your virtual assistant is a disgrace particularly as other companies use AI.
if you can't sort it out then advise me and I'll change to a different company
Avatar for Tascon
Re: Sky Go is not functioning
God your sky community is worse than the virtual assistant!
@Tascon
This is a community where Sky customers help each other, it is not a route where you can talk to Sky.
What device do you have the Sky Go app installed on ?
Are you using a VPN or if it is an Apple device do you have private relay activated ?
Avatar for Tascon
I use an IPad with VPN
Sky don't support VPNs to bypass geofencing
@Tascon
Try disabling the VPN and then see it the app works.
