This discussion topic has been answered Discussion topic: Sky Go - doesn't connect with new Q box
Message posted on 02 Mar 2023 03:24 PM
When I try to control my new Q box from Sky Go - I get this
How do I register a new Q box on Go ?
Previously - my HD box worked fine !
I can still view live channels
Just not record or view recordings
WHY ?
Message posted on 02 Mar 2023 06:05 PM
@Anonymous if you cannot set up recordings from the Sky Go app try the following
If you still have the Sky+ app log into that If you don't have the Sky + app download it and log in.
Ignore the message about having Sky Q and needing to download the Q app the Sky go app replaced this
once in the + app press the spanner at the top left goto recordings and downloads and you should be able to set your Q box in there for remote record and remote download you may need your viewing card number I cant remember if its needed or not
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 02 Mar 2023 04:12 PM
Re: Sky Go - doesn't connect with new Q box
Do you have a multiscreen sub ?
Is the Sky Go app on a device that is on the same Wifi network that your Q box is on ?
Message posted on 02 Mar 2023 04:49 PM - last edited: 02 Mar 2023 04:50 PM
@caesaromeyes and yes
I have a VIP account so run unlimited devices It fails on PC and Android
Message posted on 02 Mar 2023 04:57 PM
When you are not using your Q box have you tried rebooting it at the mains ?
Message posted on 02 Mar 2023 05:35 PM - last edited: 02 Mar 2023 05:36 PM
@caesaromeyes tried that through necessity ( it has frozen twice)
No difference
Message posted on 03 Mar 2023 09:33 AM
There is no settings spanner on my screen (PC or tablet versions)
There is only a cog symbol with.no settings option
Message posted on 03 Mar 2023 11:18 AM
did you download the Sky + app to your phone ? the spanner is in the Sky + and not the Sky go app
Message posted on 03 Mar 2023 11:39 AM - last edited: 03 Mar 2023 11:42 AM
I installed both "Go" and "+" on my tablet - I have since then uninstalled "+" leaving Go
I have installed just "Go" to my laptop and neither my tablet or laptop allow downloading !
I can watch any/all Sky channels on either/both devices but not record to Q box or local on either....
Message posted on 03 Mar 2023 06:41 PM - last edited: 03 Mar 2023 06:45 PM
Hi @Anonymous looked at both my phone and my tablet and taken screen shots of the Sky+ app they both have the spanner at the top left hand side of the Sky+ app see below
Once you click on the spanner in the Sky+ app it will tke you into the following screen
choose the frecording and download to take you into seeting your box/card as below
this should allow you to then remote record
another thing to check on the Sky Go app is to go into settings and check that connect to Sky Q box is turned on its the third option down on my phone
Message posted on 04 Mar 2023 10:29 AM - last edited: 04 Mar 2023 11:04 AM
There is NO spanner on my Go installation
on my PC
Or on my tablet
Message posted on 04 Mar 2023 01:27 PM
You are on the wrong app @Anonymous as the images posted by @Laing1 @come from the Sky+ app which can only be installed on your tablet so give this a try.
Message posted on 25 Nov 2024 11:26 AM
does not help
Message posted on 25 Nov 2024 11:43 AM
still can't get my SKY Q BOX in the bedroom working
Message posted on 25 Nov 2024 11:57 AM
In what way is it not working and how is this connected to Sky Go (where you are posting on here ) ?
