Discussion topic: Sky GO on Computer completely stuck
Message posted on 27 Aug 2024 11:58 AM
About 2 months ago, sky go on my computer started having problems connecting the application (not internet issues) I have had to uninstall and reinstall numerous times but keeps happening. Works then stops, then starts again - sometime within the same hour - but very frustrating.
I uninstalled and reinstalled but it looks like it has not installed correctly as now the app will not open - comes up with errors.
I then tried uninstalling and that doesn't work either as message saying missing "uninstall" exe file and I can't reinstall as on trying that another error message comes up.
Does anyone have any ideas how i can remove the sky go installation so that I can try installing it again?
Message posted on 08 Mar 2025 02:29 PM
Re: Sky GO on Computer completely stuck
Hey,
This is happening to me now and unsure how to solve the issue. Did you get it sorted?
Message posted on 02 Apr 2025 06:42 PM
Did either of you get this fixed? I am getting all of those error messages.
Won't open, I get java script error message.
Won't let me update, I get the abort/retry/ignore error message
Won't let me uninstall, I get the missing uninstall file message.
Very frustrating.
