Discussion topic: Remote log out users from Sky Go
Message posted on 02 Feb 2025 06:29 PM
I want remove previous devices that may of had my sky go account login on there.
I dont want them using it.
Is there a way of seeing all devices currently logged in and remove them from my account.
Message posted on 02 Feb 2025 07:24 PM
Re: Remote log out users from Sky Go
To see what devices are on your account you can do this via settings on the app itself or via this link:
https://www.sky.com/productsettings/tv
To stop people from having access to these devices first change your password:
https://skyid.sky.com/resetpassword/
Then go to this link:
https://skyid.sky.com/authorise/manage
If you tick "Sky Apps" and then the remove button, then anyone using SkyGo or SkyNews or SkySports apps etc. using your credentials will have the previous auth token removed and will be forced to sign in again (using the new password only you know). Will mean people you want to use your ID will need to do the same, but will force whoever is using your previous details off. It will not happen straight away but should stop them from using the devices over the next day or so.
Message posted on 23 May 2026 01:04 PM
Doesn't work and the second link goes to a error 404 page.
Message posted on 23 May 2026 01:14 PM
That is correct and as been reported to Sky weeks ago but they don't seem to be in a hurry to fix it.
Message posted on 23 May 2026 05:36 PM
I know it's a joke, sky told me that they had removed a user from my sky go, then I changed my password and they still keep logging in !!! Sky need to sort this out its a joke.
