Discussion topic: Recordings not showing
This message was authored by: Thegg12
Just started having problems with sky go, recordings from q box not showing, also can't find q box. All settings checked etc, turned off and deleted and downloaded app. Still no succcess
Re: Recordings not showing
@Thegg12
Try rebooting your Sky Q box at the mains, so leave it off for a few minutes then power it back up and when it has fimished loading try again to see if the app will find your recordings.
Avatar for Thegg12
Done that......still no good😔
@Thegg12
And what about your broadband router, have you rebooted this ?
