Discussion topic: I have a error code PFE 9500 how to fix?
Message posted on 03 Dec 2023 08:00 PM
I have a code : PFE 9500 everytime I start anything on Sky Go on my laptop. I have tried everything including changing the sound settings, uninstalling and reinstalling the app. I would appreciate any help. Thanks
Message posted on 03 Dec 2023 08:08 PM
Re: I have a error code PFE 9500 how to fix?
Two things to try that have worked for others in the past:
Try connecting an external speaker to your PC or Mac that you are using.
Or try reducing your sound settings from 24 bit 384 Khz to 16 bit 44.1 Khz within Windows sounds settings.
Message posted on 03 Dec 2023 09:07 PM
Thank you for your prompt response.
Unfortunately I have tried both to no avail !
Thank you
Message posted on 14 Nov 2024 09:16 PM
Not helpful to fix the PFE9500 error problem
