Discussion topic: How do i stop permanently someone from using my sky go
Message posted on 28 Apr 2024 06:23 PM
Someone who I know is using my skygo if like to know how I can permanently stop them using my sky go please
Message posted on 28 Apr 2024 07:27 PM
							Re: How do i stop permanently someone from using my sky go
First change your password:
https://skyid.sky.com/resetpassword/
Then go to this link:
https://skyid.sky.com/authorise/manage
If you tick "Sky Apps" and then the remove button, then anyone using SkyGo or SkyNews or SkySports apps etc. using your credentials will have the previous auth token removed and will be forced to sign in again (using the new password only you know). Will mean people you want to use your ID will need to do the same, but will force whoever is using your previous details off, this might not stop them straight away but it will over a day or so.
