Discussion topic: How do I change device pin?
This message was authored by: HanM
Message posted on 28 Dec 2024 09:17 PM
Sky Help doesn't detail where and how to change device pin
Find out more
Message posted on 28 Dec 2024 10:10 PM
Re: How do I change device pin?
If the Sky Go app is not connected to a Sky Q box then the pin for it can be reset or set up here:
https://www.sky.com/productsettings/tv/parental-controls
