2
This discussion topic has been answered Discussion topic: Error Code: PFE 9009-IH on SKY Go (Correct SKY subscription required)
This message was authored by: Del21690
Using SKY Go, every selection I try, with the exception of BBC 1 and 2, results in an Information Box saying I need the correct SKY subscription to watch and an error code: PFE 9009-IH. I have a full subscription and have used SKY Go successfully previously.
Avatar for Del21690
This message was authored by: Del21690 Answer
Re: Error Code: PFE 9009-IH on SKY Go (Correct SKY subscription required)
Thanks for the reply, but I eventually removed and reinstalled the App which seems to have fixed the problem. I probably should have done that first thing!!
Cheers,
Del
@Del21690
If you have made no changes recently to your account like going from Sky Q to Glass or stream then try  running Sky Go as an administrator.
Avatar for Del21690
Cheers,
Del
