11 Aug 2022 02:33 PM
As expected 10 mins on the phone only to say it's a glitch and nothing they can do 🤬
18 Aug 2022 01:39 PM
Sky go won't work on 4g but will on Wi-Fi
18 Aug 2022 01:42 PM
Posted by a Superuser, not a Sky employee. Find out moreWhat is happening, if you see an error message what does it say ?
18 Aug 2022 01:47 PM
Your devise needs authorised
18 Aug 2022 04:09 PM
Posted by a Superuser, not a Sky employee. Find out moreWill it work if you delete it here:
https://www.sky.com/myaccount/tv/manage-devices
Then reboot your device.
Failing that can you connect to Wifi then turn it off and connect to mobile data ?
18 Aug 2022 06:01 PM
Did not work and still only works on my wi fi
18 Aug 2022 07:21 PM
Mine is also not working, been the same since last week. Showing a range of error codes when accessing through mobile data but works fine on Wi-Fi.
has been showing a range of error codes such c17.2, saying device not authorised and others. These seem to almost constantly rotate. As I will try once, and try again in 2 minutes and the error code would have changed. Clearing cache, deleting app, resetting password and devices assigned to me account hasn't worked. Some further help would be appreciated otherwise we are getting into refund/cancel territory
18 Aug 2022 07:26 PM
Posted by a Superuser, not a Sky employee. Find out moreHas anyone contacted the apps team at Sky about this - apps@sky.uk
Let them know what device you are using and the software it is running and as much details on the error(s).
23 Aug 2022 06:11 AM
Sky to on iphone 13- Works fine on wi fi - hotspot to ipad though phone (3) is amazing - Works over movile with a vpn.
so deleted sky go app and the vpn
turned off relay in icloud - redownloaded sky go - still exactly the same
oh yes aky news on sky go works over 4g/5g
23 Aug 2022 09:17 AM
Posted by a Superuser, not a Sky employee. Find out moreWhat is happ[ening when you try to ise Sky Go via a mobile data network as you haven't said ?
23 Aug 2022 09:31 AM
Morning, Good point
it spins then firstly gives error message 10 numbers ending in 21
then try again and gives error message. (17c.2)
23 Aug 2022 09:37 AM
Posted by a Superuser, not a Sky employee. Find out moreTry changing to 3G in mobile data settings as this is what seems to have fixed it for others who have reported the same error code on here.
23 Aug 2022 09:41 AM
Hi again , Unfortunately its a 13 pro and only able to change 4 or 5 g. Which i have tried a few times
23 Aug 2022 02:42 PM
If I turn off 4g and change it to 3 g on my phone it works fine,all this started after last update. I have gone every thing advised on here but only above works
23 Aug 2022 02:43 PM
It has been. Will only work if I change phone settings to 3 g
On average, new discussions are replied to by our users within 3.6 hours
