Discussion topic: Cannot use Sky Go using my daughters broadband connection on several devices
This message was authored by: Lordblakester
Re: Cannot use Sky Go using my daughters broadband connection on several devices
@Lordblakester
What is happening when you use Sky Go on these devices, do you see an error message and if you do what does it say ?
Avatar for Lordblakester
 “There has been a problem connecting to the Sky Go network.”
@Lordblakester
What devices is the app installed on and could anything like a VPN be running because if so it will need disabling.
It won't work on a Playstation 4 or 2 different Iphones, works fine using any other boroadband or 4g 5g
Sounds like an issue with her broadband, btw Playstation would require Sky Go Extra for that to work
Have you tried rebooting the broadband router?
