8
This discussion topic has been answered Discussion topic: Cannot set PIN on PC for Sky Go.
This message was authored by: BexXXx
I have set a pin on my Sky 'puck' and this works fine but if I try to watch the same program on Sky Go on my PC it requires a Pin. When I enter the pin I use on the puck I get a message telling me to set one up on my PC but all links and advice on the Sky site seem to point back to setting a pin up on a puck or Sky Glass etc. and NOT on how to do it on the PC with Sky Go.
When in my Sky account (My Sky) I only seem to have the option to change the PC (device) name. Nothing appears regarding the Pin or parental security.
This message was authored by: Annie+UK Answer
Re: Cannot set PIN on PC for Sky Go.
See Q13 of my Sky Go FAQ
Avatar for BexXXx
Many thanks, that sorted my problem for me. So grateful. However, it would have been nice to have found the answer easily on Sky's own help pages or to have got help from their IA assistant. They should be paying you and the others that problem shoot their system for free. I'd never have found that page without your help.
Thanks again.
Thanks again.
We do get some benefits from Sky 🙂
@BexXXx
The Sky website isn't the easiest to navigate but this yesterday does get asked on here regularly, yesterday was the last time so the link to save to set it up or change it is this one:
https://www.sky.com/productsettings/tv/parental-controls
This message was authored by: Tattie+man
Cannot set pin on sky go on my iPad
@Tattie+man
My post above yours explains how to do this so what issue are you having doing this ?
Many thanks sorted my problem
Thanks for sorting my problem
