Discussion topic: remote control
This message was authored by: Dannib1
Message posted on 21 Sep 2025 09:19 PM
remote control
The back won't stay on so would like a new remote control, is this possible?
Find out more
Message posted on 21 Sep 2025 11:28 PM
Re: remote control
Hi @Dannib1 and welcome to the forum. This a customer forum so you are not addressing Sky. You will need to call them to explain the issue and ask for a replacement.
Are you sure you are fitting it properly as I have never seen your issue but have seen many many many posts from people who are unable to remove the back as it is so stiff.
