Discussion topic: portable stand for glass 60'" tv
Message posted on 18 Jul 2025 09:34 AM
I have a 60" glass tv and could not move it on its sideboard when getting to the on/off switch I want a portable stand. Any suggestions?
Message posted on 18 Jul 2025 09:42 AM
Re: portable stand for glass 60'" tv
Have you considered using a smart plug between your Glass's mains plug and the mains socket? You can then turn if off at the plug remotely, using your mobile.
The mains plug for my Glass is also awkward to get to, but it's a doddle with a smart plug.
Message posted on 18 Jul 2025 01:00 PM
@Mark39 wrote:Have you considered using a smart plug between your Glass's mains plug and the mains socket? You can then turn if off at the plug remotely, using your mobile.
definitely this ! i have a tapo smart plug and i can either use alexa to voice command it off and back on or use the tapo app on my phone
