Discussion topic: broadband speed
Message posted on 16 Feb 2026 11:35 AM
broadband speed
Would 76mbps be sufficient for Glass downstair plus 1 puck upstair using UHD ?
Plan to hard wire etherent for the Glass and wifi for the puck
anyone ?
Message posted on 16 Feb 2026 12:21 PM
Re: broadband speed
@cooter29 wrote:Would 76mbps be sufficient for Glass downstair plus 1 puck upstair using UHD ?
anyone ?
On paper, yes, but in practise it's really impossible to tell with any certainty. Every household is different, every broadband connection is different. Stream pucks and Glass TVs require as fast and stable a connection as possible. The Glass TV on ethernet should be fine with UHD but a Stream puck upstairs would need a very stable WiFi connection in order to maintain a reliable UHD stream.
The only way to know if it'll work well enough for you is to try it.
