Discussion topic: Wall mount
This message was authored by: Deborah4444
Wall mount
Can anyone tell me if the bracket used on the glass TV is able to come away from the wall and twist and turn like other mounts it doesn't look like it from what I've seen on YouTube
Re: Wall mount
@Deborah4444
You may be looking at content relating to the Gen 1 Glass, which has a completely fixed wall plate.
The Gen 2 Glass wall mount has some motion.
Avatar for Deborah4444
Re: Wall mount
hi I'm not sure which glass TV that I've ordered just one that the advertising it's coming tomorrow and I've just sort of realise that I don't think it's gonna be a wall mount twists and turns which is what I'd prefer
Re: Wall mount
I've just looked and it's a glass medium I've got Wi-Fi so I'm assuming that they'll I'll be able to work it through Wi-Fi but I don't think that the wall mount twists and turns
Re: Wall mount
Glass, medium
Re: Wall mount
Glass, AIR MEDIUM
Re: Wall mount
@Deborah4444
The Gen 1 Glass was the model produced between 2021 and 2024, and has a fixed low-profile wall plate included as a component of the furniture stand.
The Gen 2 Glass was released in February 2025, as was Glass Air: neither of those comes with a wall mount unless one is specifically ordered.
Re: Wall mount
@Deborah4444 wrote:
Glass, AIR MEDIUM
If you ordered the wall mount from Sky along with the Glass Air TV then yes, it does have a small amount of pull out, left/right movement.
Re: Wall mount
Thank you
