Discussion topic: Wall mount sky glass
This message was authored by: Joanna-
Message posted on 11 Jan 2026 06:42 PM
I have just ordered a sky glass tv. Any recommendations the best slimline bracket. Can I use any normal bracket? What fittings is are on reverse of tv?
Find out more
Message posted on 11 Jan 2026 06:56 PM
Re: Wall mount sky glass
Hi @Joanna-
Sky sell their own wall mount. However Glass is compatible with any VESA mount. You just need to ensure that it is rated for the weight of the TV as these are heavier than normal TVs.
See: https://www.sky.com/help/articles/sky-glass-wall-mounting-guide
MikeAlanR
