Discussion topic: Volume goes to maximum
Message posted on 13 Aug 2025 12:48 PM
Volume automatically jumps to 100%. Tried resetting remote, paired a second controller used on the sky puck and issue still happens, hard reset tv, still the same. Disconnect batteries from controller, turn tv on at the button and the volume automatically jumps to maximum so I can rule out its an issue with the controller. Any ideas?
Message posted on 13 Aug 2025 01:43 PM
Re: Volume goes to maximum
@SamCorlyon wrote:Volume automatically jumps to 100%. Tried resetting remote, paired a second controller used on the sky puck and issue still happens, hard reset tv, still the same. Disconnect batteries from controller, turn tv on at the button and the volume automatically jumps to maximum so I can rule out its an issue with the controller. Any ideas?
How old is the TV? If you've had it less than 2 years and it's still in warranty then give Sky a ring for further troubleshooting and potential replacement.
If you're outside the warranty period then there's not a lot you can do. Do you have Sky Protect device insurance which covers your Glass TV?
Message posted on 13 Aug 2025 03:45 PM
This is a 'feature' of these TVs. It's irrelevant the age of the Glass, mine does it from time to time, one of the many annoyances with these devices. A quick power-cycle seems to rectify it.
Sky Glass 65” [Gen 2]
Sky Glass 43” [Gen 1]
Sky Stream Puck x4
Sky Ultimate TV, Sky Sports, Sky Cinema, Whole Home, UHD&Atmos, Ad Skipping
FTTP Broadband [900/110]
Sky Mobile SIMO x7
Message posted on 13 Aug 2025 07:36 PM
The TV is 2 and half years old so it's not covered under warranty, disappointing really that sky only offer a short warranty, they must know the product is inferior. Won't be purchasing another one that's for sure.
Message posted on 13 Aug 2025 07:38 PM
Power cycle doesnt seem to rectify this issue, left it off overnight, thought id cracked it and 10mins later, wham next door but one can hear what im watching!
Message posted on 14 Aug 2025 04:36 PM
@SamCorlyon wrote:The TV is 2 and half years old so it's not covered under warranty, disappointing really that sky only offer a short warranty, they must know the product is inferior. Won't be purchasing another one that's for sure.
Unfortunately Sky Glass is churned out to the mass market hence being "inferior" people would be far better off buying a normal smart TV and getting pucks. For the price you pay for Sky Glass, you will get a higher quality TV for the same price.
Message posted on 14 Aug 2025 04:46 PM - last edited: 14 Aug 2025 04:48 PM
@Dazzasky I couldn't agree more. I took advangtage of the 2023 Black friday specials and purchased a Samsung TV and soundbar, sold my Glass TV and replaced it with a stream puck. Both the picture and sound are much better than Glass and I have never regretted this decision.
Also the Samsung comes with a free 5 year warranty as opposed to the short Glass 2 year warranty.
