8
This discussion topic has been answered Discussion topic: Volume Control on Sky Remote App
This message was authored by: falbs
I like using the app on my phone to control my Sky Glass TV as I struggle with the physical remote due to disability, but there doesn't seem to e a way to change the volume.
Or am I missing something?
This message was authored by: mikealanr Answer
Re: Volume Control on Sky Remote App
Hi @falbs
You are correct. However you could use the far field mic. "Hello Sky increase volume" or "Hello sky set volume to x".
MikeAlanR
Hi @falbs
MikeAlanR
Avatar for falbs
Level 3 icon
Thanks Mike, every day's a school day
Avatar for falbs
Level 3 icon
Unfortunately, using voice control to change the volume doesn't work with an external soundbar.
This message was authored by: Madidi
You can use your airplay to increase and reduce volume. When casting using airplay you can control the volume via airplay
Avatar for falbs
Level 3 icon
Sorry, not familiar with Airplay. What would I be casting, and where to?
This message was authored by: Jporch316
Hi @falbs
you should be able to alter the volume on the soundbar with the soundbar remote
This message was authored by: Heymacarenaboi
Yayy? 🥳 Sky has now added volume control onto the Sky Remote App
Avatar for falbs
Level 3 icon
Excellent News
