Discussion topic: Voice control
Message posted on 24 Mar 2024 07:22 PM
Voice control
Hi I'm just wondering if you can use voice control to put pin into movies on sky glass? Reason being our remote has broke and isn't useable
Message posted on 24 Mar 2024 08:19 PM
Re: Voice control
Hi @Lily0803
Don't think it's possible: https://www.sky.com/help/articles/voice-control-sky-glass
I've just quickly tried and not got it to recognise a pin.
If you have a Sky Q remote, you should be able to pair it and use it.
MikeAlanR
Message posted on 25 Mar 2024 01:31 PM
Re: Voice control
If the remote had a stopped working try giving it a twist in both hands in opposite directions ... this can sometimes give you a few more days use
if it's broken in another way then you ll have to get a replacement
