3
This discussion topic has been answered Discussion topic: Voice control activates randomly (button not pressed)
This message was authored by: Wildroverandy
Very occasionally we get the search bar pop up all on its own, and then the voice control listens to whatever is being spoken off the TV audio. It might then switch away to show the search results, or even go to whatever programme was found.
We're nowhere near the remote, it's often just sat on the coffee table.
Any ideas what might be activating it?
Cheers.
Andy H
Sky Stream, Sky Glass Air 43", Sky FF 150.
This message was authored by: mikealanr Answer
Re: Voice control activates randomly (button not pressed)
Hi @Wildroverandy
Sky glass has 2 mics on far field that is listening for you to say hello sky and the other on the remote. Sometimes it gets it wrong. You can disable the far field mic by pressing the button on the side of the TV or the menu accessed by the 3 white dots on your remote.
This will not affect the remote mic function which will continue to work when pressing and held.
MikeAlanR
Hi @Wildroverandy
MikeAlanR
Avatar for Wildroverandy
Level 3 icon
Great, thank you, I'd thought it was only accessible by the remote.
I'll try that later.
 Thanks again.
Andy H
Level 3 icon
I was hoping to come back and mark as answered, after I'd confirmed it was that. It was, but I got beat to it by another user.
So I just wanted to confirm this was my solution, and thank you.
Andy H
