Discussion topic: Using headsets with an optical cable with Sky Glass
This message was authored by: murtazaamin
I've recently got myself a Sky Glass, which does not have any optical cable port.  My Sennheiser headsets which I used to use with my previous TV set, can't be plugged into Sky Glass.  Anyone ever faced this issue, and has any ideas/suggestions?
Re: Using headsets with an optical cable with Sky Glass
@murtazaamin
Typically you'd need an eARC or ARC audio extractor, and then an analogue audio to optical audio converter (or the equivalent as a single unit) going from the ARC port (HDMI #2) on the Glass set.
