4
This discussion topic has been answered Discussion topic: Using Sky Glass with BT box?
This message was authored by: Kevin3103
Hi
I'm looking into cancelling my Sky subscription and moving to BT box as the cost of Sky is getting ridiculous, I have spent hours online chatting to them as my subscriptions are due to end, and they are not prepared or able to offer anything that is competitive to the BT offering, so I have tried my best to stay with Sky.
The real question is, does anyone know or have knowledge if a BT Box will plug in and work with Sky Glass V1 ?
appreciate any help!
This message was authored by: mikealanr Answer
Re: Using Sky Glass with BT box?
@Kevin3103
BT's television product is called EETV and works with BT broadband and EE broadband as they are the same company. It is a simple case of plugging in via a HDMI port and using that for your TV viewing.
Your glass will function as described here without a Sky subscription: https://www.sky.com/help/articles/sky-glass-without-a-subscription
MikeAlanR
Why wouldn't it ?
@Kevin3103 if by 'BT box' you mean a router or Hub, yes, it will work with Sky Glass. My Glass and Puck work reliably with a BT hub.
@Kevin3103
MikeAlanR
Avatar for Kevin3103
Thanks that helped , just wanted to make sure before I made the switch 👍
