Discussion topic: Uhd setting problem
This message was authored by: DAVYT1
Uhd setting problem
As soon as I set my resolution on my sky puk to uhd it doesn't load tv guide . Programs pause and is constantly saying please wait . As soon as I set it too 1080p it works fine . Any answers anyone . Thanks David
This message was authored by: peter-marlow+1966
Re: Uhd setting problem
Is your  tv a 4k tv ?
P c marlow
If not it will  not work, are you  paying  for uhd in your package , I have an old lg tv and it not a 4k tv, ,
P c marlow
Check your  tv picture  settings  to to see if you have uhd, aswell not sure what else  to  suggest hope this helps you
P c marlow
This message was authored by: PaulB1969
It may be as simple as the HDMI cable , can you borrow a HDMI 2.x cable to check it out as a lower quality may throw things off
Sky Glass (S-43) Gen1 and Gen2 , 3 Sky Stream , Sky Broadband Full Fibre (FTTP) 1 Gbps , 3 Sky Max Pods
