Discussion topic: UHD
Message posted on 23 Jun 2024 07:57 AM
UHD
I can not watch UHD in my room, I can watch only in my living room.
Message posted on 23 Jun 2024 08:25 AM
Re: UHD
@Nilson1 what device are you using to get the programming? If it is a Glass TV it is fully UHD compliant but you have to buy the UHD and Dolby Atmos pack to see Sky content in UHD. Of course you also need a decent wifi signal to carry the up to 30Mb/s UHD programming requires.
Message posted on 23 Jun 2024 08:31 AM
Re: UHD
Thank you for answering.
I have tv sky puck, my internet is ultra fast.
I love formula 1 and I have add in my playlist and, I pay monthly for UHD but I cannot watch in my room in UHD, I can watch only in HD.
Message posted on 23 Jun 2024 08:40 AM
Re: UHD
What connection speed does the Netflix Network check on the Puck report in your room?
Message posted on 23 Jun 2024 08:43 AM
Re: UHD
It is about 250 Mbps average.
Message posted on 23 Jun 2024 08:54 AM
Re: UHD
Try playing a high bit rate UHD demo in YouTube is nerd stats mode for 5 or 10 mins. Do you get any dropped frames?
Message posted on 23 Jun 2024 03:22 PM
Re: UHD
Is your tv UHD capable?
Sky Ultimate and whole home, Diamond VIP User
BT Hybrid FTTC, BT Smart Hub 2 + 1 disc
Message posted on 23 Jun 2024 04:50 PM - last edited: 23 Jun 2024 04:51 PM
Re: UHD
@bayardm wrote:Is your tv UHD capable?
This .....
your "other tv" must be uhd / 4k compatible. Smaller televisions (if that's what you have in your bedroom) don't support uhd
if it is a 4K tv make sure you go into the picture settings and check that uhd is set as the picture quality
