Discussion topic: Tv will not connect broadband
Message posted on 22 May 2024 10:06 PM
Message posted on 22 May 2024 10:12 PM
Re: Tv will not connect broadband
Hi @Becs1978
Have you reset your network settings and joined your glass to your new broadband?
Go Settings > network (scroll right to reset)
Select Reset.
Wait while your network is checked, then select Confirm.
Now, follow the on-screen instructions to:
Connect to a Sky hub
Connect to a router from another provider
Connect with an Ethernet cable instead of WiFi
https://www.sky.com/help/articles/sky-glass-no-wifi-connection-osm
MikeAlanR
Message posted on 22 May 2024 10:20 PM
I've done all of that it finds the router I put in the password it says connecting then comes up with there is a problem connecting to the broadband router
Message posted on 23 May 2024 06:59 AM
@Becs1978 if you now have a Sky hub there is a simpker way to connectvthe TV. Choose the Sky broadband option thst puts the TV into a mode which searches for compatable router then go to your new Sky hub press and hold in thecwps button on thecright hand edge unitl the led starts flashing in a few seconds if the TV is within rangectgectwo should link.
