3
This discussion topic has been answered Discussion topic: Tv unit
This message was authored by: nicnat
Tv unit
Has anyone had an issue with mounting the 65 inch tv on the stand and then on a media unit? Because of the weight??
This message was authored by: GD1 Answer
Re: Tv unit
@nicnat  Depending on the unit and if it can take the weight (which should be detailed in the instructuons), I have a Media uniyt that is designed for 70" TV's and above and can easily take  a Glass TV.
However if the unit is only a small unit it would be safe to say it wouldn't take  a large/heavy TV.
Re: Tv unit
Just make sure the media unit can take the weight... and get accidental damage cover on your home contents insurance.
Avatar for nicnat
Re: Tv unit
Thank you- I did contact one company whose media unit I was going to order but they didn't know 😂😩
Re: Tv unit
