Discussion topic: Tv problems
This message was authored by: Stuholmes123
Tv problems
I'm having issues with my sky glass tv,
every so often it has trouble connecting to the WiFi.
it also comes up with a message saying having trouble loading content so I have to turn it off at the mains and then it's ok.
This message was authored by: Jporch316
Re: Tv problems
Hi
ate you able to connect via ethernet cable or powerline adapters ? Sound like the wifi signal is weak arriving at your tv
This message was authored by: MariaGui
Re: Tv problems
I'm having the exact sme problem, nd I'm connected through the ethernet cable, very max speed but my skyglass keeps saying wait for the program to load, then switches itself off.
