1
This discussion topic has been answered Discussion topic: There is a technical fault, please try again later
This message was authored by: Mish21
Looked at other messages and not found a solution, been trying to get hold of a phoen number for sky as the virtual support is not helpful and neither is the troubleshooting. Restarted, reset etc and no joy. WiFi is connected and working, on the TV is say connection strong, but on my service status section says connection poor. Can anybody help?
Avatar for Mish21
This message was authored by: Mish21 Answer
Re: There is a technical fault, please try again later
DID THE RESET OF THE BOX AND SEEMS TO HAVE WORKED. NOT SURE HOW TO CLOSE THE DISCUSSION
Avatar for Mish21
