Discussion topic: Technical problem
This message was authored by: Bierton
Technical problem
Tv not tuning in saying there's a technical problem for the last 15 mins
This message was authored by: lefty51
Technical fault
My tv goes off and says there is a technical fault
Re: Technical fault
Watching men's tennis final and now mist it as glass tv is disgraceful i pay £130 a month for a service I don't get i demand a refund for this month as it happens on a regular basis
This message was authored by: Richard_1
Technical fault on all channels
I have a message saying there is a technical fault on all of my channels just it has just happened now 7th sept Ive tried turning everything off and back on again and still nothing I've checked on the service checker and everything is green and all good on my end can anybody help before I call sky themselves
This message was authored by: DaveGibb
Tv says No. Apparently says all ok....
TV says there is a technical fault try later. App says no faults. Yet I can't watch any film
Re: Technical problem
Hi @BiertonA restart of your Glass TV will probably resolve the issue (until the next time).
To do this go to Settings > System Management > Resets & Updates > Restart device.  It takes about 3 minutes to completely reboot and you will have a blank screen for a couple of minutes before the Sky logo appears.
This message was authored by: Hollie993
Re: Technical fault
Same here
This message was authored by: AUSPOM7
TECHNICAL FAULT MOVIES
Not able to view SKY movies or series for past 3 hours
