Discussion topic: Technical fault
This message was authored by: Bbb1999
Message posted on 15 Aug 2026 12:18 PM
Technical fault
if I go onto any channel it says loading for a bit then with an error message or technical fault message. On apps it either doesn't load the actual film or show or it plays for a bit then the sound carries on playing while the screen goes black.
please help.
This message was authored by: DAVE2027
Message posted on 15 Aug 2026 12:31 PM
Re: Technical fault
Ive had this problem for 3 weeks now i have followed all suggestions online, but to no Avail Last Saturday it took over 6 hours to sort out, its getting ridiculas now, im trying to find a number as i belive the Glass has a fault.
