Discussion topic: Technical fault
This message was authored by: JonnoBlue
Message posted on 04 Feb 2026 11:13 AM
Technical fault
Sky glass tv and pucks showing technical fault. Programs will load and run for a few minutes only, then technical fault message
This message was authored by: Jporch316
Find out more
Message posted on 04 Feb 2026 12:12 PM
Re: Technical fault
hi @JonnoBlue
try pulling the plug for a few minutes. this often clears one off glitches. If problems persist please post back in this thread
