Discussion topic: Technical fault tv
This message was authored by: Donnalou68
Message posted on 28 Apr 2026 08:07 PM
Technical fault tv
No tv reception
Find out more
Message posted on 28 Apr 2026 08:10 PM
Re: Technical fault tv
Hi @Donnalou68
You will need to provide more information such as is this a new install? Has it been working previously? Who is your ISP? What broadband speed etc do you get and what speed does your glass get? And what have you done to resolve so far?
A reboot is a good starting point. Remember we are fellow customers here on the community and no nothing about you or your set up unless you tell us.
MikeAlanR
