Discussion topic: Technical error
This message was authored by: Naoise1
Technical error
Keeps saying their is a technical error when trying to watch anything on the sky
This message was authored by: Gincap
Re: Technical error
That is generally down to poor connectivity a weak WiFi signal mostly. Check it in the Netflix app under settings if weak move the router or connect an Ethernet cable.
Rebooting power off on can also help.
