Discussion topic: Spare parts
This message was authored by: Kbabehhh
Message posted on 28 Jan 2026 01:31 AM
Spare parts
Does anybody know if I can buy the screw part for my sky glass I've got the black bracket just none of the screws or Bolts or little bits?
This message was authored by: mrwwt
Message posted on 28 Jan 2026 09:15 PM
Re: Spare parts
They don't provide them with the bracket because there isn't really a standard one. The bolt and wall plug you need depend on your home. For example if you live in a new build you likely have plasterboard which requires either a special type of wall plug or or long bolt that can screw into the breeze block.
