Discussion topic: Soundbar problem
This message was authored by: Satch1
Soundbar problem
My Orbitsound sound bar makes a horrendous noise when using the optical lead. All worked well on my Sony TV?
any suggestions?
Re: Soundbar problem
@Satch1 given your question is not relevant Waht's on Sky TV if you post the Sky box your sound bar is connected to it can be moved to the relevant forum. Hiwever most likely cause is that the sound bar is incompatable with audio type being sent to it. Try changing the output to PCM.
Avatar for Satch1
It's on a 55" Sky Glass air. What's your point?
That the Glass forum is more likely to yield a useful response.
