Discussion topic: Sound update
This message was authored by: Gin1977
Sound update
Hi does anyone know when the skyglass is coming out it says this month but what date I'm having sound issues.
When I try to watch Neflix and other apps when people talk I carnt hear them bit the music is always loud.
Re: Sound update
@Gin1977  Do you mean Software update?    These are generally done in batches so a firm date can never be provided.
Avatar for Gin1977
Re: Sound update
Yes I mean a software update.
Re: Sound update
Software updates aren't necessarily monthly, and as already advised by @GD1 when they do get rolled out, it happens in batches typically over a couple of weeks, so there is no knowing when you would receive a new software update once Sky have released a new version.
This message was authored by: Jporch316
Re: Sound update
@Gin1977
If you check the sound settings on glass there are a few settings you could try ..... one of them is specifically designed to enhance the speech
This message was authored by: Joe_Joe
Re: Sound update
In regards to the sound you're hearing (and I don't mean to sound obvious) but have you considered the location of your t.v? I mean are you sat to close to it? As the sound could be bouncing of ant walls nearby and going behind you instead of at you. Try moving further away and see if that helps ( you'll be surprised) .
Re: Sound update
Excuse the grammar errors. Can't seem to edit..
Re: Sound update
@Joe_Joe I'm not sure of the logic behind the decision but you can only edit your posts once you reach level 3 on the community forum (120 points) 🤷‍♂️.
