Discussion topic: Sound sync
This message was authored by: JM2010
Sound sync
My Sky Glass TV has started to be out of sync across all channels. I have changed channels and it temporarily fixes it. I have turned off at the mains plug and it temporarily fixes it. It also freezes at the start and will respond intermittently with voice command.
This message was authored by: J_ham
Re: Sound sync
Posted by a Sky employee
Hi there @JM2010 , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
This message was authored by: Gincap
Re: Sound sync
Big problems with latest software update, check which version you are on and take a look here.
https://helpforum.sky.com/t5/Sky-Stream/QS040-040-00P-Issues/m-p/5347269#M80968
