Discussion topic: Sound problem
Message posted on 21 Dec 2023 10:38 AM
Sound problem
My sound on my new sky glass tv rattles with low frequencies and sounds terrible
Message posted on 22 Dec 2023 01:48 PM
Re: Sound problem
@no1liverpoolfan I suspect you have been unlucky and have received a faulty Glass TV. I have one and for a TV has a great sound with no speaker vibration at all. I have seen other post where people have had a similar complaint to yours and the general advice was to contact Sky and request a replacement.
Good luck 🤞🎅🏻
Message posted on 22 Dec 2023 08:05 PM
Re: Sound problem
I received mine on Tuesday and have exactly the same issue as you - sounds terrible and bass vibration.
Called Sky yesterday and did a video call with them. They agreed it appears to be broken and is now due to be replaced next Tue (27th).
🤞🏼the replacement don't have the same issue.
Message posted on 26 Dec 2023 10:59 AM
Re: Sound problem
I've had 3 now and all have the same issue.
Once you hear the vibration / crackling bass it's very hard to un-hear it.
The only way to test whether this is an issue generally with the tv is to go down to a Sky Store and ask them to demo a tv with a movie that you have experienced the sound with. That's what I'm intending to do when shops reopen. I'm literally on the verge of sending the tv back and going back to Q
Message posted on 26 Dec 2023 11:23 AM
Re: Sound problem
Oh no that's not great.
If I get another broken one then I will just return it as I'm still in my 30 day cooling off period and will get another stream box instead.
I'm happy with the improvements that Sky have made with Stream over Q.
Message posted on 26 Dec 2023 11:57 AM
Re: Sound problem
Just an FYI for every replacement tv they give you you get another 30 day cooling off period -
Message posted on 26 Dec 2023 12:50 PM
Re: Sound problem
@Karan_Solanki wrote:Just an FYI for every replacement tv they give you you get another 30 day cooling off period -
@Karan_Solanki replacements are usually refurbished Glass TVs as well ☹️
Message posted on 26 Dec 2023 12:51 PM - last edited: 26 Dec 2023 12:53 PM
Re: Sound problem
Unfortunately that tells you nothing about the bass speaker in the set which will be delivered to your address: they are fairly unlikely to have a dodgy one on display...
It's not a 'general issue' but undoubtedly occurs in a percentage of shipped hardware, apparently due to insufficient quality control during manufacturing.
Message posted on 19 Feb 2024 05:31 PM
Re: Sound problem
I Have had a sound issue with sky glass tv where the sound bar buzzed at low frequencies, any bass sound was pretty bad. It wasnt like it when i got it and I had not over ran the speakers, couldnt contact sky becUse the glass tv was given to me.
today after looking at a schematic of the tv I removed the 20 odd screws
on the bottom of the tv and removed the bottom plate, when i inspected the sub woofer there was a piece of nylon sticky tape used presumeably to hold a cable away from the speaker face, it had attached itself to the speaker and was the cause of all the buzzing and rattling
