Discussion topic: Sound issues on All channels
Message posted on 21 Nov 2025 05:53 PM
Message posted on 21 Nov 2025 06:23 PM
Re: Sound issues on All channels
Hi @Pitottia
What broadband speed are you getting and what speed is your glass getting? (You can check this in netflix> profile pic > get help? > Connectivity check).
Issues like this usually point to poor connectivity or low broadband speeds. You may find using ethernet cable or home plugs and turing WiFi off in settings may bring more stability.
MikeAlanR
Message posted on 22 Nov 2025 11:02 AM
Hello
We had fibre broadband installed and sice then we've had issues on and off but the last 2 days it's been constant.
Message posted on 22 Nov 2025 11:10 AM
@Pitottia wrote:
Hello
Great, but what is the speed being reportedin the netflix app as requested by @mikealanr
