Discussion topic: Slow connection
This message was authored by: Patsy28
Slow connection
New to sky , streaming to the TV has at least a 2 minute connection time should it not be instant .I have tried resetting the sky max  hub  it still takes time to connect is this normal ?  Once it connects cannot fault the service.k
Re: Slow connection
@Patsy28  No, you're streaming, there will be a delay to Live channels, however startup shouldn't be 2 minutes.
What speed wifi is being received at the puck?   Open Netflix on the puck, go to get help, run connection test
