Discussion topic: Skyglass gen 2 43” wall mount
This message was authored by: Chris532
I think I must have accidentally discarded my skyglass gen2 43" wall mount with the box. Can anyone recommend a suitable alternative mount. Thanks
Re: Skyglass gen 2 43” wall mount
@Chris532  Unless you ordered a wall mount at the time you won't have been sent one.  Did you order a wall mount at £99 at the time?
Avatar for Chris532
Oh no - I wasn't offered the opportunity to buy one!! Can I do that on the Sky website then?
@Chris532  Unless it's changed the option was only available at the time of placing the order for Gen 2 Glass
Avatar for Chris532
Thank you for that. how absolutely ridiculous! Especially as the option was not given to me at the time!!
Avatar for Chris532
Can anyone recommend an alternative then?
@Chris532  If the order was placed online the option should have been there as it is now https://www.sky.com/glass/buy/personalise-sky-glass?irct=web-glass-home-hero-buy-gbr-glass-gen2-all-...
Avatar for Chris532
Not online- I ordered over the telephone unfortunately.
