Discussion topic: Sky tv doesn’t work
Message posted on 06 Jul 2024 10:42 AM
Sky tv doesn’t work
Awful sky glass. Constantly freezing
Message posted on 06 Jul 2024 10:43 AM
Re: Sky tv doesn’t work
Have sky fibre. Regulrly drops from 300mbps to 60 until reset. Needing to donthat every few days.
Message posted on 06 Jul 2024 10:44 AM
Service is a waste of money
Message posted on 07 Jul 2024 11:35 AM
@Jim75r wrote:Have sky fibre. Regulrly drops from 300mbps to 60 until reset. Needing to donthat every few days.
That would be why your sky glass keeps freezing. Maybe worth troubleshooting your internet connection with sky customer services
Message posted on 07 Jul 2024 11:37 AM
60mps should still be enough. Sky glass is appalling as is the customer service. Like so many others I would not recommend. This is after multiple engineer visits.
Message posted on 07 Jul 2024 11:41 AM
@Jim75r wrote:60mps should still be enough. Sky glass is appalling as is the customer service. Like so many others I would not recommend. This is after multiple engineer visits.
My glass unit never freezes ..... I would hazard a guess that on top of the slowdown you are getting brief internet dropouts which is affecting your glass tv
Message posted on 07 Jul 2024 11:43 AM
You'd expect the engineers to have identified and resolved? This is my second unit. I purchased fibre as this was happening on a copper connection. Still not resolved.
Message posted on 07 Jul 2024 12:07 PM
@Jim75r wrote:You'd expect the engineers to have identified and resolved? This is my second unit. I purchased fibre as this was happening on a copper connection. Still not resolved.
The network drops would be related to your home network not the Glass Tv. There are numerous things that will cause interference with people WiFi networks that are out of the control of the ISPs. The best most ISPs would offer is an higher tier booster type package where they may provider WiFi extenders or a better router. Typically the standard routers that come from an ISP are cheap and basic and there are many external factors that cause WiFi network interference.
Where is your router positions? Is it out in the open? Not on the floor? Away from radiators?
Have you tried connecting via Ethernet instead of WiFi ( or indeed vice versa if you can currently using Ethernet)?
Message posted on 07 Jul 2024 01:12 PM
Is your router's sync speed varying?
If so it would be an issue for Openreach to resolve😉
Sky Stream needs a stable connection between router and internet ... for there to be a stable connection for Stream device to have a stable connection to the Sky Servers🤔
Message posted on 07 Jul 2024 01:59 PM
A question you'd expect the so called engineers to resolve. The service and quality and lack of resolutions have been ongoing
Message posted on 07 Jul 2024 03:37 PM
Visits from Openreach or Sky?
Openreach personnel have nothing to do with Glass hardware.
Message posted on 07 Jul 2024 03:38 PM
Yes had open reach and sky engineers.
Message posted on 07 Jul 2024 04:01 PM
Why did Sky engineers visit ... what did they look at?
Message posted on 07 Jul 2024 05:52 PM
The router is 5m away in line of sight.
Message posted on 07 Jul 2024 06:57 PM - last edited: 07 Jul 2024 06:58 PM
So the Sky engineer came to measure the distance from the router to the Sky Glass TV?
