Discussion topic: Sky remote
Message posted on 17 Aug 2024 02:51 PM
Sky remote
Message posted on 17 Aug 2024 03:01 PM - last edited: 17 Aug 2024 03:03 PM
Re: Sky remote
@Kerrie5 Try to pair the remote again as follows:
- Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
- Press 4 and 6 together for three seconds
- Press 1 and 3 together for three seconds (bluetooth mode). A connected message should appear on your screen, press continue and it's all done.
If that doesn't help then have a look at the links below are to remote troubleshooting guides:
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth. Even though it sounds an unlikely solution it has got many faulty remotes working again (including my own).
If none of the above help then I would request a replacement at the following link: Streaming TV replacement remote
If you are lucky enough to have one available you can use a Sky Q remote while you wait for a replacement to arrive.
