Discussion topic: Sky next generation
Message posted on 12 May 2026 03:11 PM
Sky next generation
Can you use sky glass next generation with your existing sky package for sky glass
Message posted on 12 May 2026 03:14 PM
Re: Sky next generation
@darren+wills You can use Sky Glass Gen 1 & Gen 2 TV sets with your Subscription if you have a Whole home sub which allows up to 3 Glass TV's & 5 Pucks under the Whole Home sub.
Message posted on 12 May 2026 03:16 PM
So you still need a puck for the second sky glass next generation television in bedroom ?
Message posted on 12 May 2026 03:33 PM
If you have Glass TV's you don't need a puck at all. A puck is for standard TV's which doesn't have the Sky OS built in.
