Discussion topic: Sky live camera mount
This message was authored by: Craig54
Simple question that I cannot find an answer to - can I mount the camera below my sky glass tv
Re: Sky live camera mount
Hi @Craig54
Officially the camera is for use on top of th TV and is designed to be held there with the magnet etc. Technically there isn't anything stopping you from trying it, however (from experience using it) you may experience issues with some of the games etc as they are expecting a specific view of you or need to be able to see all of you in frame for it to work. Putting it underneath my prevent this unless you have plenty of room. The other thing is it may also obscure the sensor for Glass when you wk into the room etc if in front.
There was a YouTube review of the camera where someone put it underneath without too much issues, but having trouble finding the video.
MikeAlanR
This message was authored by: 82bit
Yes I have both my cameras below both my Glass TVs - because they are wall mounted. Placing them on top as intended results in them being 'too high' and not being too usable. Bit of a design flaw if you ask me.
Sky Glass 65” [Gen 2]
Sky Glass 43” [Gen 1]
Sky Stream Puck x4
Sky Ultimate TV, Sky Sports, Sky Cinema, Whole Home, UHD&Atmos, Ad Skipping
FTTP Broadband [900/110]
Sky Mobile SIMO x7
Is that because the TV is mounted high on the wall?
How high is the top of the TV?
Avatar for Craig54
Yes it is wall mounted and sat in a recess so only have space below the tv which is at about 100cm from the floor
That position would be very low?
Is there no way to lower the TV to allow a gap to fit the camera?
