Discussion topic: Sky glass technical problems with channel
Message posted on 23 May 2026 10:16 PM
My sky glass just recently keeps having faults with live TV.
1) states technical issue with this channel
2) when watching F1 for example it suddenly fast forwards the viewing for a few seconds.
3) Subtitles suddenly come on then a few minutes later the coverage feeezes then disappears.
Message posted on 23 May 2026 10:39 PM
Re: Sky glass technical problems with channel
Also now happening with all of my Pucks! Read trust pilot on sky glass and reviews of this tv are awful.
Message posted on 24 May 2026 12:06 AM
I've had Sky Glass and a puck for two years with little problems. Most of what you describe is down to your broadband connection. Sky Glass/Stream needs a fast and stable broadband connection. If you can use an ethernet cable, try that. The best way to check is to open Netflix on your Glass TV, go to the help section and select check my network. This will give you the speed your TV is actually receiving.
Message posted on 24 May 2026 08:20 AM
Thanks for the reply, my internet speed is very good 155 mbs. Really odd how it would still struggle with this kind of connection / speed?
Message posted on 24 May 2026 12:18 PM
No that speed is fine. Is your router in the open, ie not in a cupboard? Are the pucks situated behind the TV ? Are you getting interference from neighbouring properties? Who is your isp? Is your TV located near or far from the router? There's so many variables that can make Glass/Stream a nightmare for some. If you can use an ethernet cable to connect to the TV that would help.
