Discussion topic: Sky glass remote
This message was authored by: Val8912
Message posted on 09 Apr 2026 08:56 AM
Sky glass remote
I have a sky glass tv and a normal TV with a puck in the same room. The second remote turns the sky glass off when I switch the normal TV on. Can I unpair the remote from the sky glass please?
Find out more
Message posted on 09 Apr 2026 11:42 AM
Re: Sky glass remote
Hi @Val8912
Yes you can unpIr and it will work in IR mode with limited functionality (i.e. no voice commands).
You can do this in settings > system management> devices > Bluetooth (IIRC as not at home to check).
MikeAlanR
